Forum >SEN0385 with raspberry pi
userHead ben.dowrick 2023-06-07 07:28:32 596 Views3 Replies
Hello will the SEN0385 temperature/humidity sensor work with the rapberry pi model b, also I am looking at using it with temperatures up to 90Deg c.
Otherwise has anyone an alternative sensor that will work, can be on a cable through into the oven.
many thanks
Ben
2024-09-02 22:50:54
I would like to take quote for SEN0385 part one of my new project with different slab quantity like 200, 500,1000, 2000
can you please share concern person email id to drop a RFQ.
userHeadPic MAHESH.NASH
2023-06-08 00:51:01
The sensor uses IIC protocol, it has supporting libraries for raspberry pi, please find the files in the following link: https://gitee.com/DFRobot/DFRobot_SHT3x
The working temperature of the sensor ranges from -40 to 125℃ but the protective shell of the sensor is made of PE which can usually withstand 80℃.
Regards,
userHeadPic xingzhao.zhu
