Forum >Firebeetle:: Arduino IDE Setup failed, can't download: package_DFRobot_index.json
userHead Ray.Hill 2023-06-08 06:16:12 1108 Views2 Replies
Following instructions as stated here: https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654
At sub 8.2 Configure Arduino IDE:  https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654#target_9
Instructions tellme to download: https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json into the IDE via FILE/Preferences.
An error occured, error text:
"Some indexes could not be updated. Get "https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json": tls: failed to verify certificate: x509: certificate has expired or is not yet valid: : https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json"
Trying to open this file in a browser results in a certificate error (SSL_ERROR_BAD_CERT_DOMAIN)
The Certificate is issued to: “*.dfrobot.com.cn” but the domain name where the file should be downloaded from is “*.dfrobot.top”. So there is a domain mismatch.
Also the certificate is expired, validity until: Thu, 05 Nov 2020 03:54:06 GMT
Arduino IDE verrsion: 2.1.0
2023-06-08 20:20:24
pls try the url:http://download.dfrobot.top/FireBeetle/package_DFRobot_index.jsoninto the IDE via FILE/Preferences.
userHeadPic jenna
Henry.Miller wrote:
Hmmm… that URL gives the same failure response now. Please could someone find a working URL for us, and update the manual? Many thanks!
2023-11-14 05:45:11
