Forum >SEN0366 usb/ttl computer connexion and command
Troubleshooting
userHead art.mox 2023-06-11 12:06:05 1192 Views2 Replies
hello
i just bought a SEN0366 laser meter sensor
i am trying to connect it via the ttl usb adaptator
CH340 driver is already installed
is there any wiki to show how to use it
i try to send the command line 80 06 02 78
with termite 3.4 (a freindly RS232 communication tool)
but i got no return
the usb-ttl seems to work fine with other device
i would like to use the arduino IDE to send direct command line but i don't now how.
i try the serial monitor without arduino board but with the usb/ttl
i could choose the port but for the board whitch one ??????
the final goal is to use the laser with a pic18 MCU for remote sensing.
currently i use pic instead of arduino but electronic and serial communication are the same for everybody.
so if you have information about all command line of the laser i am searching that.
and witch protocol is used (if it is not RS232)
thanks !!!!!
and if anybody now how to use it just with a computer thanks to.
2023-11-07 14:12:59
Note: The 80 06 02 78 command is in binary, for which you type hexidecimal. Be sure “termite” has a facility to send that message by way of translating it from hexidecimal to binary. You may have to put that command into a file using a hex editor, and then send the file. uCon, another terminal emulator, has the provision to send a message that you specify in hexidecimal.
The electrical signalling of this device is 3.3 volt TTL asynchronous, as described in #3 of previous reply. DO NOT connect to a true RS232 device.
userHeadPic Digital Lives Matter
2023-06-13 00:34:55
usb-ttl adaptator        SEN0366
       TX                                RX
       RX                                TX
      GND                            GND
      VCC                             VCC(3.3V~5V)
1. Connect usb-ttl to computer USB
2. Open the serial monitor and select the corresponding port.
3. Set the baud rate to 9600bps, 8 data bits, 1 start bit, 1 stop bit, no parity, send hex
4. Send command: 80 06 02 78
userHeadPic jenna
