Forum >LattePanda DC 5.5x2.1mm Power Cable
userHead Se3ri0us 2023-06-14 22:41:54 654 Views2 Replies
Dear Support,
Can you please tell me the name and dimensions of the small white plug that plugs into the LattePanda 3 Delta to power it? I plan to use an adapted cable.
Thanks!
2025-03-05 16:06:36
1. Interface: JST PH2.0 - 4pin (the pin diagram is also marked on the board: - DC ++, indicating two negative pins and two positive pins)
2. Interface: JST PH2.0 - 4pin
userHeadPic jenna
2023-06-15 02:03:46
Thank you very much for the information! This is what I was looking for!
userHeadPic Se3ri0us
