Forum >SEN0211 AC current Sensor and ESP32
TroubleshootingGravity
userHead Luis.Correa 2023-06-16 13:42:24 1413 Views2 Replies
Hi,  I am trying to read the SEN0211 AC current sensor,  with the AC Current Sensor V1.0 board and a ESP32  ,  I am readin a fan , wich with a multimeter reads 0.645amp  , but with de ESP32 I only read 0.   even floating the Analog input gives noise but with the wire of the sensor reads 0.
2025-02-27 14:15:40
Please use it with ADS1115 module.
I simulate your project using ESP32-E, ADS1115, and the DAC module. (This DAC module is I2C communication, 2 channels of 0~10V or 0-5V analog voltage output with 12bit resolution and 0.5% accuracy.  )
I set the DAC module to output 1.22V. At the same time, I measured the output voltage of ESP32-E as 3.29V. #define VREF 3.29
As can be seen from Figure 2, the voltage read using the ADS1115 code is 1226mv. Further using the formula in the code to convert, the final stable result is 2.17A. (This output has been rounded.)
Hope that helps.
code:
#include <Wire.h>
#include <DFRobot_ADS1115.h>
DFRobot_ADS1115 ads(&Wire);
const int ACPin = A2;         //set arduino signal read pin
#define ACTectionRange 5;    //set Non-invasive AC Current Sensor tection range (5A,10A,20A)
#define VREF 3.29
float readACCurrentValue()
 if (ads.checkADS1115()){
        double ACCurrtntValue = 0;
 double peakVoltage = 0;
 double voltageVirtualValue = 0;  //Vrms
 int16_t adc0;
 double temp = 0;
 double voltage = 0;
 for (int i = 0; i < 5; i++)
   adc0 = ads.readVoltage(0);
   temp = ads.readVoltage(0);
   peakVoltage += temp;   //read peak voltage
   delay(1);
 } peakVoltage = peakVoltage / 5;
 Serial.print("A0:");
 Serial.print(adc0);
 Serial.println("mV,  ");
 ACCurrtntValue = peakVoltage /1000 * 1.7675;
 Serial.print(ACCurrtntValue);
 voltage = peakVoltage / 1000.000;//real voltage
 Serial.print("real voltage:");
 Serial.println(voltage);
  voltageVirtualValue = voltage * 0.707;    //change the peak voltage to the Virtual
//The circuit is amplified by 2 times, so it is divided by 2.
 voltageVirtualValue = voltageVirtualValue / 2;
 ACCurrtntValue = voltageVirtualValue * ACTectionRange;
 return ACCurrtntValue;
     else
       Serial.println("ADS1115 Disconnected!");
       return 0;
 Serial.begin(115200);
 pinMode(D9, OUTPUT);
   ads.setAddr_ADS1115(ADS1115_IIC_ADDRESS0);   // 0x48
   ads.setGain(eGAIN_ONE);   // 2/3x gain
   ads.setMode(eMODE_SINGLE);       // single-shot mode
   ads.setRate(eRATE_128);          // 128SPS (default)
   ads.setOSMode(eOSMODE_SINGLE);   // Set to start a single-conversion
   ads.init();
 float ACCurrentValue = readACCurrentValue()/1.00; //read AC Current Value
  //Serial.print("voltage: %.3fV\n", ACCurrentValue);
 Serial.println(" A");
 digitalWrite(D9, HIGH);
 delay(500);
 digitalWrite(D9, LOW);
 delay(500);
userHeadPic jenna
2023-06-18 03:45:06
Before proceeding as per Jenna's instructions, you can test the current sensor with an Arduino UNO. You can connect and code according to this wiki page: https://wiki.dfrobot.com/Gravity_Analog_AC_Current_Sensor__SKU_SEN0211_
