Forum >Reset WiFi on ESP32-E
userHead Lazzz 2023-06-19 22:31:31 592 Views7 Replies
I need to reset my WiFi to get the “Configure my-sensesp-project” message to show up again so I can connect to the correct network please.
TIA
2023-06-20 23:17:22
1. You can add some print information in the code, in order to know which step of the program has a bug.
2. It is recommended that you try to change the wifi.
3. You can refer to the sample code to test whether the esp32-E has the same problem.
wiki:
https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654#target_23
sample code:
userHeadPic jenna
Lazzz wrote:
Thanks, I'll see how I go.
2023-06-22 20:17:03
2023-06-20 23:08:13
Hello Lazzz,
I have read the tutorial, It seems that you are stuck on this step:
I suggest you try to upload the code again, remove any shield you have, check for the power supply and then press the RST bottom on the board.
Best regards.
userHeadPic xingzhao.zhu
Lazzz wrote:
Thanks, I'll give it a go.
2023-06-22 20:16:35
2023-06-20 14:49:48
I am just following along with this tutorial: Getting Started | SensESP documentation (signalk.org)
userHeadPic Lazzz
Lazzz wrote:
Here: https://signalk.org/SensESP/pages/getting_started/
2023-06-20 14:51:25
2023-06-20 00:14:12
Could you pls upload the code or project link? Thanks for more details.
userHeadPic jenna
