Forum >Beetle ESP32 (DFR0575) and ESP32-C3 (DFR0868) direct battery supply
userHead dftimo 2023-06-27 06:26:16 1872 Views1 Replies
Can I connect a battery directly to the following boards:
https://www.dfrobot.com/product-1798.html
https://www.dfrobot.com/product-2566.html
I saw 2 threads with similar topics:
https://www.dfrobot.com/forum/topic/320276
https://www.dfrobot.com/forum/topic/316826
But neither says if this is supported and more importantly, how to actually connect them? I was thinking of soldering something like https://bc-robotics.com/shop/jst-ph-2-pin-cable-male-conenctor/ on to the board to then connect it to the JST PH connector on LiPo batteries, but where to connect the connector? Which pins should I use on either board for the red and black wires on the connector?
2023-06-28 01:38:54
You can solder the two wires from the battery to the BAT and GND of the ESP32-C3. There is a TP4057 lithium battery charging management chip on the ESP32-C3. You can charge the battery via the ESP32-C3's USB.
You can solder the two wires from the battery to the VIN and GND of the Beetle ESP32. The Beetle ESP32 cannot charge the battery.
userHeadPic jenna
