Forum >More trouble with DFROBOT Ethernet W5500 shield
TroubleshootingArduino
userHead Luke.Bonnici 2023-06-27 20:20:23 651 Views1 Replies
I am also having trouble with this shield:
IDE version: 2.1.0
Library: ethernet 2.0.2
Board: UNO
Issue: The below code initializes to tell me on the serial port that the “server is at 192.168.13.14” however, my PoE switch does not learn the MAC of the board, thus no layer 3 comms.
Code:
#include <SPI.h>
#include <Ethernet.h>
#define SS     10U    //W5500 CS
#define RST    11U    //W5500 RST
// Enter a MAC address and IP address for your controller below.
byte mac[] = {  0xB3, 0x8D, 0x72, 0x1D, 0xCE, 0x91 };
// Our IP address
IPAddress ip(192,168,13,14);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
    pinMode(SS, OUTPUT);
  pinMode(RST, OUTPUT);
  digitalWrite(SS, LOW);
  digitalWrite(RST,HIGH);  //Reset this module
  delay(200);
    digitalWrite(RST,LOW);
  delay(200);
 delay(200);
  // Open serial communications and wait for port to open:
  Serial.begin(115200);
  //while (!Serial) { } // wait for serial port to connect.
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print(F("Server is at "));
  Serial.println(Ethernet.localIP());
  }  // end of setup
// how much serial data we expect before a newline
const unsigned int MAX_INPUT = 100;
// the maximum length of paramters we accept
const int MAX_PARAM = 10;
// Example GET line: GET /?foo=bar HTTP/1.1
void processGet (const char * data)
  // find where the parameters start
  const char * paramsPos = strchr (data, '?');
  if (paramsPos == NULL)
    return;  // no parameters
  // find the trailing space
  const char * spacePos = strchr (paramsPos, ' ');
  if (spacePos == NULL)
    return;  // no space found
  // work out how long the parameters are
  int paramLength = spacePos - paramsPos - 1;
  // see if too long
  if (paramLength >= MAX_PARAM)
    return;  // too long for us
  // copy parameters into a buffer
  char param [MAX_PARAM];
  memcpy (param, paramsPos + 1, paramLength);  // skip the "?"
  param [paramLength] = 0;  // null terminator
  // do things depending on argument (GET parameters)
  if (strcmp (param, "foo") == 0)
    Serial.println (F("Activating foo"));
  else if (strcmp (param, "bar") == 0)
    Serial.println (F("Activating bar"));
  }  // end of processGet
// here to process incoming serial data after a terminator received
void processData (const char * data)
  Serial.println (data);
  if (strlen (data) < 4)
    return;
  if (memcmp (data, "GET ", 4) == 0)
    processGet (&data [4]);
  }  // end of processData
bool processIncomingByte (const byte inByte)
  static char input_line [MAX_INPUT];
  static unsigned int input_pos = 0;
  switch (inByte)
    case '\n':   // end of text
      input_line [input_pos] = 0;  // terminating null byte
      if (input_pos == 0)
        return true;   // got blank line
      // terminator reached! process input_line here ...
      processData (input_line);
      // reset buffer for next time
      input_pos = 0;
      break;
    case '\r':   // discard carriage return
      break;
    default:
      // keep adding if not full ... allow for terminating null byte
      if (input_pos < (MAX_INPUT - 1))
        input_line [input_pos++] = inByte;
      break;
    }  // end of switch
  return false;    // don't have a blank line yet
  } // end of processIncomingByte
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client)
    Serial.println(F("Client connected"));
    // an http request ends with a blank line
    boolean done = false;
    while (client.connected() && !done)
      while (client.available () > 0 && !done)
        done = processIncomingByte (client.read ());
      }  // end of while client connected
    // send a standard http response header
    client.println(F("HTTP/1.1 200 OK"));
    client.println(F("Content-Type: text/html"));
    client.println(F("Connection: close"));  // close after completion of the response
    client.println();   // end of HTTP header
    client.println(F("<!DOCTYPE HTML>"));
    client.println(F("<html>"));
    client.println(F("<head>"));
    client.println(F("<title>Test page</title>"));
    client.println(F("</head>"));
    client.println(F("<body>"));
    client.println(F("<h1>My web page</h1>"));
    client.println(F("<p>Requested actions performed"));
    client.println(F("</body>"));
    client.println(F("</html>"));
    // give the web browser time to receive the data
    delay(10);
    // close the connection:
    client.stop();
    Serial.println(F("Client disconnected"));
  }  // end of got a new client
}  // end of loop
2023-06-28 22:53:32
It is recommended to upload the sample code and check the web page for output. If this step doesn't work, you may need to change the computer's adapter settings and recheck the hardware wiring.
userHeadPic jenna
