Forum >A01NYUB Ultrasonic Sensor no data, SEN0313
userHead Katrin.Kat 2023-06-29 01:49:30 1035 Views7 Replies
Hello!
I bought A01NYUB Ultrasonic Sensor with the Raspberry Pi IO Expansion Board and I use a Raspberry Pi 4B. I have followed the instructions accordingly https://wiki.dfrobot.com/A01NYUB%20Waterproof%20Ultrasonic%20Sensor%20SKU:%20SEN0313 and https://www.dfrobot.com/forum/topic/317449. But unfortunately I still get “No data!”. Why do I not get any distance data?
Thanks for the support in advance!
2023-07-07 05:45:04
It works fine without epansion board, see also https://www.dfrobot.com/forum/topic/312660
userHeadPic Katrin.Kat
2023-07-05 07:21:50
Are you using jumper wires? If yes, test them too.
Katrin.Kat wrote:
Do you mean between RasPi and Expansion Board?In this case, no.
2023-07-06 05:46:51
2023-07-04 01:21:00
No difference, still no data. I don't see any difference in the code either.
Katrin.Kat wrote:
We have made some progress and have found that it is because the io extension hat huts off after a while. When the board is working we get distance readings. After a while the extension shuts off. Is this a defect or a setting issue?
2023-07-05 02:51:59
jenna wrote:
It seems like the expansion board has some errors. You can consider changing the expansion board if it works well between RasPi‘s GPIO and SEN0313.
2023-07-06 19:39:11
2023-06-29 18:09:35
Please try the latest sample code. We will update the wiki.
https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW/blob/master/DFRobot_RaspberryPi_A02YYUW.py
userHeadPic jenna
