Forum >SEN0470 and SEN0471
General GravityArduino
SEN0470 and SEN0471
userHead Manel.Barroso 2023-06-30 00:12:57 559 Views3 Replies
How to connect SEN0470 and SEN0471 to the same arduino board?
2023-06-30 03:17:09
Problem solved.
userHeadPic Manel.Barroso
2023-06-30 02:32:29
The real problem is to define the two sensors in the arduino ID.
2023-06-30 02:12:54
SEN0470 /SEN0471    arduino UNO
SCL------------------------------->SCL
SDA------------------------------->SDA
VCC------------------------------->5V/3.3V
GND------------------------------->GND
At the same time, you need to adjust the I2C addresses of the two sensors to be different.
userHeadPic jenna
