Forum >Voice Recorder Module Breakout SKU DFR0745 Play Rec GPIO Pins
userHead Abhishek.Kumar2745 2023-07-01 10:02:06 850 Views3 Replies
Voice Recorder Module Breakout SKU DFR0745 Play Rec GPIO Pins I cannot find anywhere
can i short it with ground without any resistor to record or play?
(I am not able to upload picture it always gives 10 mb error )
2023-07-03 18:54:11
wiki: https://wiki.dfrobot.com/Voice_Recorder_Module_Breakout_SKU_DFR0745
It is recommended to add the corresponding resistors to control pins.
userHeadPic jenna
2023-07-03 05:30:24
Okay but still there should be proper documentation for those pins and also so many things are buggy in this forum. You can outsource this to our company if you are not able to maintain it
userHeadPic Abhishek.Kumar2745
2023-07-02 17:53:08
Yes. You can try,  no harm to the board.    You won't break it.
userHeadPic R2D2C3PO
