Forum >DS1307 and battery problem
TroubleshootingGravity
userHead Francois.Richard 2023-07-03 23:03:30 312 Views5 Replies
I have 2 x DF1307 gravity modules and I got the same behavior with both of them connected to a ESP8266 :
- When the CR1220 battery is not inserted,   the DS1307.begin() function is returning true, and time is moving forward. - When the CR1220 battery is inserted (with the + on the top)    the init function is returning false and time is stuck at 0.
I am missing something ?
2023-07-04 23:49:43
The working voltage of the DS1307 is 5V. I think this is more like a bug if you power the module from the 3V3 PIN of ESP8266.
userHeadPic Yeez_B
Francois.Richard wrote:
Good catch !!!working great powered with 5V
thanks much !
2023-07-05 01:09:57
2023-07-04 09:10:53
I got 2 cells one is 2.8V and the other 3.1Vsame problem with both.The device is completely useless without this power backup feature for me.
userHeadPic Francois.Richard
2023-07-04 06:14:55
Measure the battery voltage. Check if it is giving 3V or not.
Same problem with both.The device is completely useless without this power backup feature for me.
2023-07-04 09:11:48
