DFR0941 DAC board install for piCorePlayer
I just installed the DFR0941 DAC board on a Raspberry Pi 4B to use with piCorePlayer. The card is supplied with 5V 1A.
Is it necessary?
I searched the forum, read the WIKI and I can't get it to work.
In the WIKI you say to use the HiFi-Box DAC driver but this driver is not available. Nor is it in the Volumio disk image.
It is clearly mentioned on the site that this card is compatible with piCorePlayer.
Could you help me please?
Thanks in advance.
Hi!
Yes, I read this wiki well and it doesn't help at all.
I installed Volumio just to test because there is a HiFiBox driver but it does not work and returns an ALSA error message.
Very disappointed with this purchase.
Hi!
Sorry for the inconvenience. Could you pls send some videos or pictures to the technical support mail? We will test again according to your step and get back to you as soon as possible.
It is recommended that you use piCorePlayer, which is a system that runs on Raspberry Pi and can drive DFR0941. You can refer to the tutorial of piCorePlayer.
https://docs.picoreplayer.org/getting-started/
If you're still encountering issues during use, pls feel free to upload the relevant steps and videos via Google Drive. We're here to help!
Hi!
Did you refer to this wiki? But I didn't see the driver files and other information in the tutorial.
https://wiki.dfrobot.com/SKU_DFR0941_Raspberry_Pi_DAC_Audio_Decoder_Board
