Forum >Bluno Beetle DFR0339 writes only one byte from array
userHead Dick.van Straaten 2023-07-09 23:10:43 909 Views2 Replies
I created an app that writes and reads to the Bluno using Bluetooth. Everything works fine, except when I try to read a byte array from the device I only receive the first byte, while the array has multiple bytes.
I use Serial.write(message);
Code can be found at https://github.com/Bengkel/Bengkel.Ble.
Any ideas what causes this issue? Is this device specific?
2023-07-18 02:40:13
Hi!
I tested the send.ino using Bluno and it works fine. Please refer to:
userHeadPic jenna
2023-07-11 06:02:25
Please check if there is a baud rate mismatch.
