Forum >SEN0291 Library Issue?
I'm using the Arduino and Raspberry Pi code from: https://github.com/DFRobot/DFRobot_INA219
Using a 24 vdc power supply the SEN0291 always reports a negative BusVoltage. E.g. BusVoltage: -8.14V
Other ina291 libraries report the correct BusVoltage as does a DMM.
Thanks for the help.
2023-07-12 06:20:04
bidrohini.bidrohini
Please double-check all the connections with this wiki page:
https://wiki.dfrobot.com/Gravity:%20I2C%20Digital%20Wattmeter%20SKU:%20SEN0291
Make sure that your sensor is properly calibrated. Also, make sure that your power supply is not fluctuating.
