Forum >SEN0257 (Analog Water Pressure Sensor), wrong voltage
TroubleshootingGravity
userHead Brian.Moulson 2023-07-18 03:25:10 904 Views3 Replies
Hi, I bought this Gravity: Analog Water Pressure Sensor a couple of months ago and just got around to trying it. I have connected it to my water supply which is at 5 Bar but I am only getting 1.5V from the gauge, The data sheet says it should be 2.5V, Has the spec changed?
2023-07-19 00:09:12
ESP8266 D1 Mini
userHeadPic Brian.Moulson
bidrohini.bidrohini wrote:
Checking it with an Arduino UNO will be a good idea I think.
2023-07-19 07:43:35
2023-07-18 22:03:25
Hi!
Sorry, we will revise the specification information.
What board do you use?
userHeadPic jenna
