Forum >Light Disc with 7 SMD RGB LED Connected to an Arduino Pi Pico
Troubleshooting
userHead bryce.lindstrom 2023-07-19 18:56:45 351 Views3 Replies
Try to do something very simple but struggling.
Just trying to do testing with a Light Disc with 7 SMD RGB LED Connected to an Arduino Pi Pico.
Using the following code. I have included a photo of our setup. The code goes on but we aren't getting any lights.
Any help would be much appreciated.
int B = 3; //Connect Blue led to Digital pin 3
int R = 5;//Connect Red led to Digital pin 5
int G = 6;//Connect Green led to Digital pin 6
//Connect the 5V pin of light disc to GND Pin of Arduino
 pinMode(3,OUTPUT);
 pinMode(5,OUTPUT);
 pinMode(6,OUTPUT);
 digitalWrite(B,random(255));
 digitalWrite(R,random(255));
 digitalWrite(G,random(255));
 delay(80);
2023-07-21 20:05:50
Thanks for your reply. LED lights power up fine when installing code (i think they're meant to flash to acknowledge this has happened). So I don't think it's a power supply issue.
userHeadPic bryce.lindstrom
jenna wrote:
Hi!
1.
I checked the information on Arduino Pico. Please try the analogWrite() function, it might work.
https://arduino-pico.readthedocs.io/en/latest/digital.html
This is the document of random(). The random function generates pseudo-random numbers.
https://www.arduino.cc/reference/en/language/functions/random-numbers/random/
The ADC bit of RP2040 is 12bit and the range of ADC is 4096.
pls try this code.
int B = 3;
int R = 5;
int G = 6;
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT); }
analogWrite(B,4096);
analogWrite(R,4096);
analogWrite(G,4096);
delay(80); }
2. I checked the information on Arduino Pico and found that its pin current is relatively small. Compared with the current specification of the 7 SMD RGB LED, this may cause the LED not to be driven.
2023-07-22 02:53:17
2023-07-20 00:30:39
Hi!
LED Power Supply: 5V
But the pico can only provide 3.3V, maybe the voltage is insufficient.
userHeadPic jenna
