Forum >DFR0745 test for end of file
ArduinoTroubleshooting
userHead jlbachiochi 2023-07-20 07:52:21 652 Views1 Replies
If i play all files in a loop…
  for(int i=0; i<=12; i++)
  Serial.println("Playing File # " + String(i));
  df1101s.playSpecFile(i);
  delay(1000);
the complete file is cut short.  Do i need to know how long each file is and put a delay after the play command?
2023-07-20 18:30:51
Hi!
You can change the mode to play all files in a loop in the setup function.
#include <DFRobot_DF1101S.h>
#include <SoftwareSerial.h> SoftwareSerial df1101sSerial(2, 3);  //RX  TX
DFRobot_DF1101S df1101s;
void setup(void){
Serial.begin(115200);
df1101sSerial.begin(115200);
while(!df1101s.begin(df1101sSerial))
{    Serial.println("Init failed, please check the wire connection!");
delay(1000);  }  /*Set volume to 20*/
df1101s.setVol(20);
Serial.print("VOL:");  /*Get volume*/
Serial.println(df1101s.getVol());  /*Enter music mode*/
df1101s.switchFunction(df1101s.MUSIC);  /*Wait for the end of prompt tone*/
delay(2000);  /*Set playback mode to "repeat all"*/
df1101s.setPlayMode(df1101s.ALLCYCLE);
void loop(){  /*Start*/
  df1101s.start();
delay(3000);
userHeadPic jenna
