Forum >Using Gravity: 360 Degree Rotary Encoder Module (SKU:SEN0502) with Bela
Gravity
userHead YashCC 2023-07-20 15:11:42 548 Views1 Replies
Hi, Is there any way to use Gravity: 360 Degree Rotary Encoder Module (SKU:SEN0502) with Bela Microcomputer? (https://bela.io/)
I am a bit new to this, so I hope this isn't too basic but I could not find a direct way to install the encoder library into the Bela IDE.
I'm really not sure how to approach trying to make this work without the library in Bela IDE. Any input would be really appreciated.
Thank you!
2023-07-20 17:21:22
Hi!
Unfortunately, there is no Bela-compatible library. This is an I2C module, you can refer to the underlying code in the library to rewrite it.
https://github.com/DFRobot/DFRobot_VisualRotaryEncoder
userHeadPic jenna
