Forum >Maqueen ultrasonic sensor
userHead Paul.Haenen 2023-07-21 17:08:28 1096 Views4 Replies
I am new to the Maqueen and Makecode combination. I am not sure why my code below does not work.
2023-07-21 18:02:40
I tried the same code in Edge, rather than Chrome and noted the “ " marks left the numbers and then it worked.
userHeadPic Paul.Haenen
xingzhao.zhu wrote:
Oh! Okay,
That explains.
Thank you!
2023-07-21 18:07:48
2023-07-21 17:53:53
Yes I copied the code from the wiki page.
The power is full, as per the photo
I am running from the latest version extension
Hope you can help
2023-07-21 17:36:07
According to the wiki page that I read, your code seems to be correct.
wiki link:
https://wiki.dfrobot.com/SKU_MBT0021-EN_Maqueen_Plus_STEAM_Programming_Educational_Robot
So in this case, could you please give us some more information about your robot's cable connection and power supply? A photo will be the best.
Thank you!
Best regards,
userHeadPic xingzhao.zhu
