Forum >LCD Shield - Temperature Sensor?
userHead HannesBK 2010-09-05 08:20:33 6125 Views2 Replies
the LCD lib comes with a demo for measureing temperature.
Which type of sensor is needed to run the demo?
Attached is a demo which sets the backlight brightness by keys.
Hannes
2022-01-18 02:41:10 Thank you so much!
celeb networth
userHeadPic leafthatneverfall
2010-09-06 23:49:15 That is a DS18B20 temperature sensor.  You can find at https://www.dfrobot.com/index.php?route= ... path=36_64 userHeadPic R2D2C3PO
