Forum >Romeo BLE Bluetooth Error
TroubleshootingBluno
userHead Joe.Blow 2023-07-25 17:58:36 747 Views3 Replies
Cannot connect to Romeo BLE through application.  I get Error 3300: Error 9101 in extension BluetoothLE: Expected device index between 1 and 6
2023-07-27 01:38:48
Hi!
Do you need to connect Romeo to your mobile phone Bluetooth? If this is the case, you need to download the Bluetooth software on your phone to communicate with Romeo, instead of using the Bluetooth settings that come with your phone. (Android system)
userHeadPic jenna
2023-07-26 04:18:59
Hi, did the above instructions solve the error problem?
2023-07-26 02:33:28
To use the BLE of the board, you can try AT commands. Please refer to this link
https://wiki.dfrobot.com/Bluno_SKU_DFR0267#Configure_the_BLE_through_AT_command
The following picture is a screenshot of the section you should look for:
userHeadPic xingzhao.zhu
