Forum >amps used needed for Gravity sensors
Good day, may I please ask what amperage the following sensors use ( I need to work out power consumption for solar)
ANALOG ELECTRICAL CONDUCTIVITY SENSOR V2
SEN0161 PH SENSOR V1.1 - ARDUINO COMPATIBLE
DHT22 TEMPERATURE & HUMIDITY SENSOR MODULE - GRAVITY SERIES
ANALOG AMBIENT LIGHT SENSOR MODULE - GRAVITY SERIES
Thank you !
2023-08-24 01:00:58
Afra
The third one is 1.5mA (DHT22 TEMPERATURE & HUMIDITY SENSOR).
Apologize that other sensors do not have known amperage parameters.
You could choose a multimeter or the ‘I2C Digital Wattmeter’ to test each sensor's current.
(SEN0291: https://www.dfrobot.com/product-1827.html)
