Forum >Pi Zero W, IO Expansion HAT and analog Gravity sensors compatibility.
userHead Jonathan.Huegi 2023-07-26 12:14:23 952 Views1 Replies
Hi, I'm planning a project that will use the following probes/sensors :
Gravity: Analog Electrical Conductivity Sensor /Meter V2 (K=1)
Gravity: Analog pH Sensor/Meter Kit V2
Gravity: Analog Turbidity Sensor for Arduino
Gravity: Analog ORP Sensor Meter for Arduino
I would like to use a Raspberry Pi Zero W I have no use for.
My question is, can I use all of the above sensors with the DFR0604  IO Expansion HAT for Raspberry Pi Zero/Zero W or do I have to use one DFR0553  Gravity: I2C ADS1115 16-Bit ADC Module for each analog sensor ?
Thanks in advance for your help !
2023-07-27 01:17:16
The DFR0604 has 4 channel ADC, I think this fits your needs. You want to use four analog sensor on the Pi Zero W.
You don't have to use the ADS1115
userHeadPic Yeez_B
