Forum >Replacing Espressif module on FireBeetle 2?
userHead tcamps 2023-07-30 09:24:28 380 Views2 Replies
I'm looking to replace the ESP32 module with a different module which has a connector for the WiFi antenna instead of a built-in antenna.
I've tried to use a hot air gun to remove the module, and since there isn't a good way to get a hold of the whole module, I end up using tweezers on the module shield instead.
Whenever I try to pull off the module, the shield comes off and the module stays attached.
Does anyone have any suggestions on how to replace the Espressif module?
2023-07-31 10:28:53
It's definitely not preferred, but I want to use the Firebeetle 2E with its onboard FPC connector and need the power of ESP32.
Sounds like I'll need to search Aliexpress and hope I get lucky, or commission a custom board?
userHeadPic tcamps
2023-07-31 00:28:53
I do not think replacing the module is a good idea. Even if you succeed in replacing the ESP32 module, the Firebeetle may not function.
You can buy a separate  ESP module according to your requirement:
https://www.theengineeringprojects.com/2021/08/esp8266-based-wifi-modules-for-iot-projects.html
