Forum >Fermion i2s mems microphone with raspberrypi
Raspberry PiGeneral
userHead Pushpendra Sharma 2023-07-30 21:24:01 2617 Views6 Replies
i want to know how to use this microphone with raspberry pi 4 4GB model.
2025-01-22 13:11:13
I am  DFrobot Fermion I2S MEMS microphone SEN0526 microphone with Raspberry pi Zero 2w
and i am doing right connection. After rebooting, I used arecord -l to list the capture hardware devices and received the following output:
**** List of CAPTURE Hardware Devices ****
and i am not able to record audio
can anyone help in this?
userHeadPic Aakash.Gupta
2023-11-04 17:09:51
I am currently working on integrating the SEN0526 I2S MEMS Microphone with a Raspberry Pi and have encountered some challenges. I have managed to record audio using the following configuration, but I am uncertain if it is the optimal setup or if there might be a better approach.
Here is the configuration I added to /boot/config.txt:
dtparam=i2s=on
dtoverlay=googlevoicehat-soundcard
**** List of CAPTURE Hardware Devices **** card 2: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 [Google voiceHAT SoundCard HiFi voicehat-hifi-0]  Subdevices: 1/1  Subdevice #0: subdevice #0
With this setup, I am able to record audio, but I am concerned about the correctness of this method since it involves using a dtoverlay intended for a different device (Google Voice HAT). I would like to know if there is a recommended dtoverlay for the SEN0526, or if there are any additional steps I should take to ensure proper functionality.
Any guidance or recommendations would be greatly appreciated.
userHeadPic Tedfsan
2023-08-01 07:48:54
It should be possible but you may need to make your own library.
2023-07-30 21:40:03
https://www.dfrobot.com/product-2637.html
userHeadPic Pushpendra Sharma
jenna wrote:
Hi!
Sorry, there is no tutorial for Raspberry Pi in this product wiki.
2023-08-01 01:47:26
