Forum >LattePanda Sigma Wake from USB via WoWWAN of SIM7600G-H-M2 connected to M.2 B Key
General LattePanda
userHead luveti 2023-07-31 15:34:08 918 Views1 Replies
The LattePanda Sigma supports Wake from USB.
A SIM7600G-H-M2 can be connected to the M.2 B Key, and it appears it's using the USB interface of this port for communication.
According to the SIM7600G-H-M2 datasheet, it supports WoWWAN for several events.
The Sigma also supports keeping USB power on after suspend/hibernate/shutdown. Does it support keeping the power on for the M.2 B Key? If not, could this be added as a BIOS option?
I believe a potential alternative, that would work with the existing bios, would be using a SIM7600G-H-M2 USB dongle. But this would be a less elegant solution. Though it would free up the M.2 B Key for other uses.
The use case would be resuming from suspend/hibernate upon a sms or voice call. With the only device consuming power being the SIM7600G-H-M2 module.
2023-08-03 17:50:20
Hi!
You can also consider making an adapter module for SIM7600G-H-M2 to convert the M.2 interface into a USB interface and connect it to the USB2.0 pin header of LattePanda.
https://www.lattepanda.com/forum/?t=876&p=1
userHeadPic jenna
