Forum >ESP32 talk with PC via Bluetooth or WiFi
userHead Hsin.Cheng 2023-08-08 13:43:07 856 Views2 Replies
I used Bluno Beetle (DFR0339) for around two years for my project. Due to the limited hardware capability of the chip (ATmega328), I recently moved to Firebeetle ESP32 (DFR0478).
When I was using Bluno Beetle, I was able to use two Bluno Beetles (one connected to PC, and the other sit remotely) to establish a Bluetooth link between a PC and a remote Bluno Beetle. I was able to do wireless programming (over-the-air program upload) and also send some commands via serial port to the remote Bluno Beetle.
I would like to ask if there are similar functions for Firebeetle ESP32? I hope to use two Firebeetle boards (one connected to PC, and the other sit remotely) to establish a Bluetooth link between a PC and a remote Firebeetle, and transfer data bidirectionally. Could anyone give me some advices?
Of course, it would be great if I can use one Firebeetle board to achieve the same function as before.
And of course, if there is a easy way to do that with WiFi, that is highly appreciated.
Thank you very much for your assistance.
2023-08-09 11:45:19
Problem solved.
userHeadPic Hsin.Cheng
2023-08-08 13:56:54
I would like to add another question: do the AT commands work with Firebeetle ESP32?
