Forum > I2C address change
I2C address change
Can I change the I2C address? I want to use two DFR0645-G.
If that doesn't change, should I use an I2C Multiplexer?
The products I use are 1 W5500, 2 DFR0645, and 2 AM2302.
I want to display different values on each of the 2 displays.
2023-08-10 06:20:22
Yeez_B
The I2C address for the DFR0645 could not be changed.
The only way to use the multiple displays in one main board is to use the I2C Multiplexer.
View Arduino ProductsMore Arduino Related ProjectsArduino TutorialsMore Gravity ProjectsView Gravity Products
