Forum >Ethernet Sync exposed on CM4 Router Board Mini
Raspberry PiGeneral
userHead Jasper.Koolhaas 2023-08-14 02:22:18 672 Views1 Replies
Are the CM4 Ethernet Sync pins (16 +18) accessible on the CM4 Router Board Mini?
That would be awesome, because a CM4 has hardware time stamping that enables time syncing (PTP / GPS + PPS) with nanosecond  accuracy!
* https://github.com/jclark/rpi-cm4-ptp-guide/tree/main* https://www.jeffgeerling.com/blog/2022/ptp-and-ieee-1588-hardware-timestamping-on-raspberry-pi-cm4
BTW: There is a typo in the title of the page: Compute Model 4 IoT Router Broad Mini
