Forum >how to get data from A02YYUW using hardware serial in Stm32 controller
General Arduino
userHead sridhar.Arul 2023-08-19 20:19:24 558 Views2 Replies
this is my arduino stm32 nucleo code .but i dont get any value .if i use software serial using i/o pin i get the data.
#include "HardwareSerial.h"
HardwareSerial SerialLP(PB9,PB8); // RX, TX
HardwareSerial Seriall {PA10, PA9};
unsigned char data[4]={};
float distance;
// Object to represent software serial port
 Seriall.begin(115200);
SerialLP.begin(9600);
   do{
    for(int i=0;i<4;i++)
      data[i]=SerialLP.read();
     // Seriall.println("E");
 }while(SerialLP.read()==0xff);
 SerialLP.flush();
 if(data[0]==0xff)
     int sum;
     sum=(data[0]+data[1]+data[2])&0x00FF;
   //  Seriall.println(sum);
     if(sum==data[3])
       distance=(data[1]<<8)+data[2];
       if(distance>0)
          Seriall.print("distance=");
          Seriall.print(distance/10);
          Seriall.println("cm");
         }else
              Seriall.println("Below the lower limit");
     }else Seriall.println("ERROR");
    delay(100);
2024-05-09 00:49:47
sir, is it working fine. Please, tell sir
userHeadPic yaswanth.kuna
2023-08-19 20:26:09
sorry i missed that. i used UART pin(hardware serial) for to get the data.
userHeadPic sridhar.Arul
