Forum >Problem with RGB LED DFR0654
userHead mikegold 2023-08-29 19:42:16 955 Views3 Replies
Hi Everyone,
When I got the firebeetle, I know the RGB LED was working because if I pressed the side button it would cycle through the colours. I tried programming it with the code from the DFR0654 wiki page but now the RGB won't turn off. Even when I load entirely different code (like the basic blink program) it won't work. I've tried this on 2 separate DFR0654's, same result.
2025-07-19 17:54:34
Well, I am going to share this soon.
https://checknolcard.com/
userHeadPic mikegold
2023-08-31 19:30:02
hi,
I understand your issue but to help you with the procedure, I want more information, The link you have provided is not enough to understand the whole code and project. share your project :)
userHeadPic Amelia.Smith
