Forum >Maqueen Plus V2 Pinout
RoboticsGeneral
userHead alexMartinez 2023-09-01 16:27:39 1288 Views3 Replies
Where I can find the Pinout for the Maqueen Plus V2?
2023-09-04 04:32:50
I found on the github page ultrasonic sensor could be connected to Pin 13 and Pin 14:
  /**    * Acquiring ultrasonic data    * @param trig trig pin selection enumeration, eg:DigitalPin.P13    * @param echo echo pin selection enumeration, eg:DigitalPin.P14    */
https://github.com/DFRobot/pxt-DFRobot_MaqueenPlus_v20/blob/master/maqueenPlusV2.ts
more info will follow
userHeadPic alexMartinez
2023-09-01 18:41:29
What a coincidence, I was reading the detailed essay on the Maqueen Plus V2 and you asked for it. It is in the "Education" section of DFRobot and I think you must read it for the details. Definitely, it is helpful for you.
userHeadPic Amelia.Smith
alexMartinez wrote:
Sorry, Not helpful, I can not find the Maqueen Plus V2 Pins conected to the micro:bit in the “Education” section.
2023-09-03 04:36:49
