Forum >How to use Azure Speech Recognition and Speech Synthesis
General UNIHIKER
userHead nick.qq2023 2023-09-07 18:22:44 1582 Views2 Replies
Official website link: https://azure.microsoft.com/en-us
Step 1: Account Login
Login with GitHub account
Login with email address
Login with phone or Skype
Click Next to complete the login
Step 2 Create resources
Step 3 Set parameters
Basics create
Subscription-> Default selection
Resource group-> Create a new resource group
Regin-> Select according to your region
Create a new project name
Pricing tier-> Depending on your choice of pricing
Then select Next.
Network selection
Then select Next.
Identity selection
Open or close according to your needs
Then select Next.
Tags choice
Default empty
Then select Next
Review + create
Review + Create
Then select Create.
Creation complete
Click on GO to resource
Get the key and Location/Region
Click the arrow to get the key and Location/Region
The Unihiker uses Azure services
Installation:
pip install azure.cognitiveservices.speech`
Usage example (code):
import time
import os
from azure.cognitiveservices.speech import  SpeechConfig
AZURE_SPEECH_KEY = "" # Fill key
AZURE_SPEECH_REGION = "" # Enter Location/Region
try:
    import azure.cognitiveservices.speech as speechsdk
except ImportError:
    print("""
    Importing the Speech SDK for Python failed.
    Refer to
    https://docs.microsoft.com/azure/cognitive-services/speech-service/quickstart-python for
    installation instructions.
    import sys
    sys.exit(1)
# Set up the subscription info for the Speech Service:
# Replace with your own subscription key and service region (e.g., "japaneast").
speech_key, service_region = AZURE_SPEECH_KEY, AZURE_SPEECH_REGION
def tts(text):
    speech_config = SpeechConfig(subscription=speech_key, region=service_region)
    speech_config.speech_synthesis_language = "en-US"
    speech_config.speech_synthesis_voice_name ="en-US-JennyNeural"
    # Creates a speech synthesizer for the specified language,
    # using the default speaker as audio output.
    speech_synthesizer = speechsdk.SpeechSynthesizer(speech_config=speech_config)
    # Receives a text from console input and synthesizes it to speaker.
    result = speech_synthesizer.speak_text_async(text).get()
def speech_recognize_once_from_mic():
    speech_config = speechsdk.SpeechConfig(subscription=speech_key, region=service_region, speech_recognition_language="en-US")
    audio_config = speechsdk.audio.AudioConfig(use_default_microphone=True)
    speech_recognizer = speechsdk.SpeechRecognizer(speech_config=speech_config, audio_config=audio_config)
    print("Speak into your microphone.")
    speech_recognition_result = speech_recognizer.recognize_once_async().get()
    if speech_recognition_result.reason == speechsdk.ResultReason.RecognizedSpeech:
        print("Recognized: {}".format(speech_recognition_result.text))
    elif speech_recognition_result.reason == speechsdk.ResultReason.NoMatch:
        print("No speech could be recognized: {}".format(speech_recognition_result.no_match_details))
    elif speech_recognition_result.reason == speechsdk.ResultReason.Canceled:
        cancellation_details = speech_recognition_result.cancellation_details
        print("Speech Recognition canceled: {}".format(cancellation_details.reason))
        if cancellation_details.reason == speechsdk.CancellationReason.Error:
            print("Error details: {}".format(cancellation_details.error_details))
            print("Did you set the speech resource key and region values?")
    tts(speech_recognition_result.text)
while True:
2024-07-29 14:05:22
I have “SyntaxError: invalid character in identifier” in line 4. I guess it is something about azure.cognitiveservices.speech installation. Could you help?
Thank you.
userHeadPic djeronimo
lia.ifat wrote:
Here is solution to this error message: https://www.geeksforgeeks.org/how-to-fix-syntaxerror-invalid-character-in-python/
2024-07-29 16:13:31
