Forum > Beetle ESP32-C3 wiring with Li-ion battery to power the board and charge from USB
userHead sdimi 2023-09-15 06:25:34 1005 Views2 Replies
I have bought a Beetle ESP32-C3 which has a built in “li-ion battery charging management”. My plan is to connect 3.7 Li-ion battery to power the board and charge the battery from the USB when is empty. If you have already done this, can you please advise on the required wiring or share the wiring diagram
Thanks in advance for the help.
2023-09-24 05:33:21
A time zone is an area which observes a uniform standard time for legal, commercial and social purposes. Time zones tend to follow the boundaries between countries and their subdivisions instead of strictly following longitude, because it is convenient for areas in frequent communication to keep the same time.
Time zones are defined as 1 or 2 offsets from Coordinated Universal Time (UTC), and (if 2 offsets are used) the days when the offset changes. Some time zones switch between offsets throughout the year due to daylight saving time (DST).[1] The UTC offsets range from UTC−12:00 to UTC**4:00, and are usually a whole number of hours, but a few zones are offset by an additional 30 or 45 minutes (such as in India, South Australia and Nepal).
Areas of extreme latitude are more likely to use DST. DST is usually used for about half of the year, typically by adding one hour to local time during spring and summer.[url=https://ufa771.bet/][color=#FFFFFF][size=1pt][b]UFA771[/b][/size][/color][/url]
userHeadPic fsdfdsfgdf.gdfgdfh
2023-09-23 01:35:21
You could use some 3.7V Lipo like this one:
And cut the white terminal on the end of the cable, then solder the positive and negative pole to the ESP32-C3.
userHeadPic Yeez_B
