Forum >Overlord Pro - Feeder Issues
3D PrintingGeneral
userHead Account cancelled 2017-11-23 15:46:05 5018 Views1 Replies
I have been having issues with the feeder for my Overlord Pro ever since I moved. The feeder works fine, but I am unable to increase the tension of the feeder, so the filament is never pulled in. I have tried to take apart the module several times, and have made no progress. Is this block replaceable?
Any suggestions would be greatly appreciated. At this point, I am ready for a new printer if this can't be solved =/
2017-11-27 19:22:20 Hi, you can adjust the hex screw in the picture to increase the tension of the extruder, this will solve the feeding issue. userHeadPic robert.chen
