Forum >Analog PH sensor with Arduino Nano IoT
General Arduino
userHead Sarina.Till 2023-09-22 04:42:56 707 Views4 Replies
Hi, I have a project that uses the arduino nano IoT board- which does not have any EEPROM, the DFRobot_PH library calls EEPROM , is there any way I can use this sensor with my Nano 33 IoT board ?
Sarina
2023-10-10 03:03:11
I have the same issue. Does anyone have a solution for this, or will I need to use a different board or PH Sensor?
userHeadPic Mark.Jones
2023-09-22 05:32:27
Maybe you need to use the EEPROM emulation library:
https://forum.arduino.cc/t/persistent-storage-for-arduino-nano-33-iot-no-eeprom/623137
It is confirmed that with Nano 33 IoT, you cannot directly use any library that calls the EEPROM. Those libraries will need modifications.
userHeadPic lia.ifat
2023-09-22 04:45:54
I think the same holds true for the PH_EC :( help please ?
userHeadPic Sarina.Till
lia.ifat wrote:
Do you mean the EC sensor? Yes. The the library is dependent on eeprom library: https://wiki.dfrobot.com/Gravity__Analog_Electrical_Conductivity_Sensor___Meter_V2__K%3D1__SKU_DFR0300
It is compatible with Arduino UNO, Mega and Leonardo.
https://github.com/DFRobot/DFRobot_EC#Compatibility
You can choose any of these boards. By the way, if you are looking for a proteus library for the PH sensor, you can get that from here:
https://www.theengineeringprojects.com/2021/10/ph-sensor-library-for-proteus.html
2023-09-29 00:23:13
