Forum >My final year project
userHead Jonathan.Witt Lee 2023-09-25 08:01:09 1449 Views3 Replies
Hi i am student. I just bought the camera from cytron. I am going to make my final year project using this camera to make a transportion robot. I want to know is it huskylens can make multiple algorithm at the same time such as line tracking and tag recognition?
2023-09-26 00:29:54
Yeah, you can use huskeylens without any hesitation. That will handle your work perfectly. By the way, as you are making a transportation robot, the build must be robust. You can follow this structure:
https://www.pcbway.com/project/sponsor/SFU_Formula_Electric_Team.html
userHeadPic lia.ifat
2023-09-25 20:03:21
Yes, the HuskyLens could do these.
You could find example in the wiki:
https://wiki.dfrobot.com/HUSKYLENS_V1.0_SKU_SEN0305_SEN0336#target_18
userHeadPic Yeez_B
tguneysu wrote:
re: huskylens can make multiple algorithm at the same time such as line tracking and tag recognition?
I was under the impression that MULTIPLE algorithms simultaneously was NOT POSSIBLE !
2023-11-18 01:22:21
