Forum >SEN046 CO accurance for ambient use
TroubleshootingGravity
userHead Roberto.Fernandez 2023-09-27 12:42:05 1226 Views0 Replies
 SEN0466
Now I have the following problem. The CO sensor placed in the window always gives values of 0 ppm (range 0-1000 ppm). If I create a bad combustion, with little oxygen, the sensor will quickly increase the measurement, so it is ok.
Would it be possible to recalibrate it to a lower scale, or buy a model with a scale of 0-100 ppm, or 0-10 ppm?
See the grafana dashboard:
Is this sensor valid for ambient meassurements?
Thanks in advance.
Roberto Fernandez
