Forum >DFR0668 output current switching
I recently purchased a DFR0668 (https://wiki.dfrobot.com/Lipo_Charger_Type_C_SKU_DFR0668) in order to charge a 1000 MAh 3.7V Lipo battery. However, I'm not sure how to change the output current. The wiki says that there are bonding pads on the back to select. Does that mean I have to solder them together ? I attached a picture of what I did to switch to 500 mA. Is that accurate ? Do I need to do something else ?
Thanks in advance !
