Forum >I'm having trouble getting the encoder outputs to work with FIT0487
userHead Andrew.Hobbs 2023-10-05 19:59:53 596 Views1 Replies
I have a setup where I'm using an FIT0487 at 6V to control the motor, while the Encoder is operating at 3.3V (confirmed by the green LED being lit). To ensure compatibility, I have connected the Encoder outputs to a 10Kohm resistor for pull-up to 3.3V. I'm unsure about the next steps to troubleshoot this.
Any suggestions? Thanks.
2023-10-08 00:41:07
This is the 12v motor module wiki, FIT0487 and FIT0403 are similar.  https://wiki.dfrobot.com/12V_DC_Motor_122_rpm_w_Encoder_SKU__FIT0403
You could check it how to use, and remember to use 6v powered on.
userHeadPic Afra
