Forum >Unihiker execute Python script at start up
General UNIHIKER
userHead RoniBandini 2023-10-06 11:40:23 895 Views2 Replies
What is the best method to execute a Python script at start up in Unihiker without getting the config and demo screen?
2023-11-30 06:44:55
Thank you very much, Afra.
userHeadPic RoniBandini
2023-10-08 01:20:12
1. You can enable "auto boot" in the "service toggle" in the home menu.2. Upload the program to Hikeboard, run it once, and then power off.3. Next time when powered on, this py file will run automatically after a 5-second countdown.   (Principle: Each time a py program is run in the "service toggle" in the home menu, the system records this file. If the "auto boot" switch is enabled, then this py file will run at the next boot.)
userHeadPic Afra
