Forum >Comprehensive FAQ Guide for UART Non-contact Optical Turbidity Sensor [SEN0554]
userHead jenna 2023-10-08 19:52:54 3112 Views0 Replies
Q1: How to calculate the conversion of AD data from sensors into dirty data?
A1: There are two formats for reading data from the host. One is dirty data, which ranges from 0 to 255, and the other is AD data, which ranges from 0 to 4095. For example, if the AD data is 0X64, which is equivalent to 100 in decimal, it needs to be mapped to the range of 0 to 255. The calculation would be 255 * 100 / 4095 = 6, so the dirty data would be 6. The corresponding voltage is calculated as 5V / 255 * 6 = 0.1V.
Q2: Can this sensor operate at a voltage of 3.3V?
A1: Yes, you will need to connect a 33R resistor in series with IO1 and IO2, and then connect it to the corresponding port on the main board.
