Forum >Comprehensive FAQ Guide for BMP388 Barometric Pressure Sensors [SEN0251]
userHead jenna 2023-10-08 20:30:18 2648 Views0 Replies
Q1: How does this sensor communicate with UNO SPI?
A1: The csPin can be set to any digital pin. Here, we choose pin 4, and the sensor's CSB is connected to UNO D4. pls download the code from here.
Q2: If temperature collection is disabled, the altitude (pressure) data may drift (increase or decrease at a certain rate) significantly beyond the normal range and cannot stabilize.
A2: Temperature is originally used to calibrate the pressure. When measuring pressure, temperature collection should not be disabled.
icon code.zip 3KB Download(0)
