Forum >M.2 B SATA socket stopped working in LP3
userHead Roman.Melnikov 2023-10-09 13:12:11 1097 Views1 Replies
Hi, Sirs,
SATA M.2 B socket on LP3 stoped working after I changed M.2 SATA SSD to SIM7600G-H LTE module. Can you, please, advise me, how to check, if SATA socket if fine ?
In the BIOS, Advanced folder, SATA device is not detected. Device manager does is not showing new device with SIM7600 in the SATA socket.
When I tried to return back M.2 SATA SSD to SATA M.2 B socket, it also stopped working and there are no changes in Device manager.
At the same time, this SSD is recognized via external USB adapter, supporting M.2 SATA 2280.
I am ready to send you LP3 for diagnostic and repair. It seems to me some electrical circuit happened.
What I need to do ?
Thank you for your help in advance.
2023-10-12 02:14:38
Please turn to the LattePanda TechSupport for help.
admin@lattepanda.com
userHeadPic Yeez_B
