Forum >Embedded Thermal Printer not functioning
TroubleshootingArduino
userHead David.Robertson 2023-10-11 11:41:03 358 Views0 Replies
I purchased 4 Embedded Thermal Printers (DFR0503-EN) and none of them work.  I'm trying to print from an Arduino using the serial input.
I've tried:
- Printing to another thermal printer (a larger one I purchase a few years ago).  That worked fine.
- Printing at both 9600 and 19200 baud (neither worked)
- Trying many different sketches.  The simplest is copied below.
- Powering the printer at 5v and 7.5v, from separate power source
I also found that the cables were reversed - the yellow and green wires (which are usually the TX and RX leads) are not the right leads into the printer.  I made sure I was sending signals to the correct inputs on the printer.
I tried a few of the code snippets you listed in the product wiki.  None worked.
Nothing has worked.  Can you give me any help?
Thanks,
Dave
CODE I TRIED:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
 mySerial.begin(9600);
 //mySerial.begin(19200);
 mySerial.println("Executing now");
 mySerial.println();
 mySerial.println();
 mySerial.println("DFROBOT");
 mySerial.println("Test 1");
 mySerial.println("Test 2");
 mySerial.println();
 mySerial.println();
 mySerial.println("Done");
 delay(5000);
