Forum >DFROBOT_RTU: ReadHoldingRegister for multiple register and conversion
ArduinoTroubleshooting
userHead Albertoz 2023-10-11 23:29:13 873 Views2 Replies
I use the DFRobot_RTU library for Modbus Master.
I use
uint8_t readHoldingRegister(uint8_t id, uint16_t reg, uint16_t *data, uint16_t regNum)
to read two holding registers (regNum = 2).
Can you give a code sample how uint16_t *data has to be defined and how the result is converted to a float value?
The Modbus data is big endian.
Thank you
2023-10-12 01:57:39
You could define an array in your code, and then pass the name of the array(which is the pointer) to the readHoldingRegister() function. Like the following:
uint16_t array[8];
int result = readHoldingRegister(0x01, 0x08, array, 2);
Then the data you need would be stored in the array. I don't know the detail for your Modbus protocol. So I assumed that the data you need was stored in the fourth and fifth byte. And the endian byte is the third byte.
So you could use the “<<” to move your third byte to get the data you need.
uint16_t data = (array[4]<<8) + array[5];
For eample, if your array[4] is 0x08, your array[5] is 0xFA.
The above line will make you get 0x08FA
userHeadPic Yeez_B
Albertoz wrote:
Thank you for pointing me to the right direction.
It seems that readHoldingRegister() returns the data value in array[0] and array[1].
So ended up with the follwing code giving the correct float value from two subsequent registers:
  uint16_t array[2];
  float floatValue;
  unsigned long *p;
  p = (unsigned long*)&floatValue;
  // read register a118 and a119 from slaveId 3
  uint8_t result = modbus.readHoldingRegister(0x03, 0xa118, array, 2);
  if(!result)
     *p = (unsigned long)array[0]<<16 | array[1];       //considers big-endian
     Serial.print("Value: "); Serial.println(floatValue);
  else
    Serial.print("Error number: "); Serial.println(result);
2023-10-16 08:47:06
