Forum >SIM7600 with arduino uno
TroubleshootingArduino
userHead Dirk.Vercauteren 2023-10-13 02:12:11 387 Views0 Replies
I am using the Arduin uno to send and receive SMS's.
I used the SIM900 platform before and that is working fine
I am using the onboard LED (pin 13) to signal a good network connetion
I am now trying to get the 4G shield (SIM7600)  to do the same.
I had to change the speed from 115200 to 19200 to get it to work correctly.
My problem is:
– everything works fine as long as the USB cable to the PC is connected!!!!
– When  disconnect the USB (after uploading the sketch) – the shield is still conneted to a stable 12volt supply (1200 mA)– The Power LED is ON, the net LED flikkers but I never get the GSM OK LED to light on!!!. And the unit does not respons to any incomming SMS's
Changed UNO board, changed power supply but no results
