What is HuskyLens?
HuskyLens is a camera and field of view component of artificial intelligence or AI to detect microcontrollers can perform smooth color images, detection of objects in space or living things and tags or symbols. Additional multifunctional console
Equipment in the standard set
1. HuskyLens camera module
2. Connection cable
3. Installation equipment
Technical features
๐ Can be connected and used with any family of contemporary microcontrollers that have UART or I2C bus connection circuits, including Arduino, micro:bit, ESP32, OpenKB and KidBright32, as well as small computer boards, Raspberry Pi or equivalent and good. HuskyLens greatly reduces the burden of complex programming for image and vision AI processing.
๐ The main processing chip is Kendryte K210.
๐ The OV2640 image detection module is a 2 megapixel camera module.
๐ Uses a power supply of 3.3 to 5V. It requires a current of 320mA during normal operation at a power supply of 3.3V or 230mA.
at 5V power supply when working in face recognition mode The display has 80% brightness.
๐ Connect via UART or I2C bus.
๐ 2-inch IPS display with a resolution of 320 x 240 dots. เว็บแทงบอลสต็ปดีที่สุด
