Forum >【help】 pH sensor Calibration
userHead rnegal01 2023-10-21 01:00:19 1265 Views1 Replies
Hello, i need help on calibrating my ph sensor, i already calibrate it but the reading is not accurate.
when i put it in 4ph solution it has a right reading but when i put it to 6ph solution the reading is getting low? anyone know how to solve this?
also if anyone know how to reset the ph sensor?
2023-10-22 05:46:56
Hi, which PH sensor are you using?
This ? https://www.dfrobot.com/product-2069.html
Or this? https://wiki.dfrobot.com/Gravity__Analog_pH_Sensor_Meter_Kit_V2_SKU_SEN0161-V2
userHeadPic lia.ifat
